what should the compression be on a 04 xl700 guys
re a 04 xl 700 compression
Re: re a 04 xl 700 compression
My compression is 135 and 140 the motor runs fine then bogs out after about 5 minutes and wont start till it sits for awhile then will run for short time agian. the water flow seems good out the pisser where do I look next ?
Check your coils (Pulse and charging) measure directly after you get the problem and see if one of them is out of spec.
Coils are located on the stator, wire connections are in the electrical box, get a manual somewhere for wire colors and specs.
Somewhere on this forum is a link to manuals.
This is in our weekly tech tip area.
The SBT tech department recommends that when performing any engine swap or top end rebuild, the installer should always have a factory repair manual present to complete the job at a professional level. This is a great link that has been passed on to us.
jmfiskin.com/manuals/
__________________SBT Tech Support is here to help with your problems.
