Choosing Correct Spark Plugs
This is a sticky topic.
  • Choosing Correct Spark Plugs
    The SBT Tech Guys Recommend: You use spark plugs that are in the specified heat range for your watercraft. Running too hot of a heat range will cause detonation, damaging your pistons and can even damage your cylinders. The lower the number on the spark plug the hotter the heat range - Example a BPR7ES is a hotter burning plug than a BPR8ES.
    Ericka Buczkowski
    What spark plugs does my friend need for his RB20 motor?? or what cars spark plugs could he use????
    bride dating
      Re: Choosing Correct Spark Plugs
      RB20 motor?
