Keeping the Engine Compartment Clean
This is a sticky topic.
  • Keeping the Engine Compartment Clean
    Tech Tip
    How to keep your engine compartment looking like new:
    Your SBT Tech Guys recommend keeping your engine compartment clean and dry at all times. Any water that remains in the hull after riding can cause condensation, causing damage to paint finishes and rusting electrical components. Water sitting in the hull can also evaporate and enter into the engine, causing internal rusting and severe engine damage. We recommend using a small amount of laundry detergent and 2 gallons of warm water to slosh around in the hull to release any oil and scum residue then rinse out with fresh water and let the engine compartment drain. We also recommend using a wet and dry shop vacuum to remove any water left in the hull, when done leave the seat cracked open a bit to allow any moisture to evaporate. Spraying pure silicone spray on the engine and electrical components will help protect the finish and add to waterproofing electrical parts.
    Ericka Buczkowski
    Re: Keeping the Engine Compartment Clean
    Good advice...
    2001 GP1200R
    Pump Seal Kit/ Solas 13/19 Impeller
    Free flow Exhaust/ Cat Temp Sen
    Riva Performance Head (140 comp)
    Single Layer Head Gasket/Jetworks Mod
    Performance pump cone/Riva Reed Stuffers
    Rejetted Carbs 125/110 1.5 n/s 95gr spring
    Modified D-plate & Ride plate/ Trim Tabs
    Stepped Sponsons/TTach/1200 Grate
    Riva Pro Arrestors
