I just purchased a Delrin wear ring from SBT. I was suprised that it slid in the the housing very easily.
The shop manuals all say that the wear ring should fit so tightly that you need a press to force it in the housing or you'll need to hit it in with a hammer and 2X4.
Also, on the delrin ring (without the bolts) I can easily turn the wear ring in the housing with very little force.
Should this be happening? Aren't the wear rings supposed to fit tighter than this?
Any input would be appreciated.
--Brian
--Brian
