Results 1 to 4 of 4
    Default Re-using Gaskets on a Motor
    In the past there has been a debate on whether or not you could re-use some of your old gaskets when working on your motor. The overall correct answer is No, but yes, you could get away with certain ones. O-ring seals that are in good condition and have been inspected, such as magneto cover o-rings, water cooling system o-rings and head o-rings could be re-used. Gaskets that should never be re-used include exhaust system gaskets, reed valve gaskets and carburetor gaskets. Using old gaskets on you intake system can result in an air leak causing a lean condition and damage your engine. Using old gaskets on your exhaust system can result in water leaking into your cylinders, causing hydro locking and other water damage.
    Always think of the consequences you may face by re-using gaskets vs. their relatively low cost!
    Ericka Buczkowski
    Apr 2010
    South Ga
    8
    Default Re: Re-using Gaskets on a Motor
    Relativley low cost????????? I bought 2 Carb base plate and a exaust pipe gasket for a 00 XL800 from a Yamaha dealer in South Ga and they were 75.00 !!!!!!! Called another dealer and he wanted more.:( But, Yes, I agree, Dont skimp on the fuel delivery or exaust...
    Jul 2001
    Jacksonville nc
    592
    $75 vs $1200 for 800 rebuild engine not to include labor WAIT let me guess!!!!!!!!!!!
    Apr 2010
    South Ga
    8
    LOL!!!! Yep.
  1. Preseason check list!!
    By jcar25 in forum Sea-Doo
    Last Post: 05-14-2006, 11:27 PM
  2. 1994 Polaris SLT SBT Motor Problems
    By sspracing in forum Polaris
    Last Post: 08-24-2005, 07:03 PM
  3. Out of Warranty Motor
    By '98 750 SXi pro in forum The SBT Experience
    Last Post: 07-11-2004, 06:36 PM
  4. What to check when buying a used ski
    Last Post: 08-01-2002, 04:47 PM
