Results 1 to 5 of 5
    Default Sea-Doo 4 Stroke Engines Losing Engine Coolant
    In the past, a few customers have contacted us because their 4-Stroke Sea-Doo is mysteriously consuming engine coolant. We have found that the two hoses inside the hull that are connected to the ride plate/heat exchanger are the hoses that are leaking. The hose clamps that are used will rust and break and when pressure is built up from the cooling system. The antifreeze will then push past the ride plate nipples and hoses. No evidence of coolant can be found in the hull because it is bilged out by the self-bailing system in the ski. Attached are a few pictures of a failing clamps and its location. Replace the clamps with a good marine grade full stainless steel clamp. This should help prevent "mysterious" coolant loss.
ID:	3027   Click image for larger version.
ID:	3028   Click image for larger version.
    Ericka Buczkowski
    Oct 2007
    Key West
    198
    Default Re: Sea-Doo 4 Stroke Engines Losing Engine Coolant
    Another one is the ride plate leaking, around the screws which hold the cover plate on the ride plate, you will never find coolant in the unit, make always sure that the sink is still on the plate, this is a common problem if the ski is used in salt water.
    21,545
    Yes I have seen antifreeze leak around the Zinc mounted to the ride plate, thats easy to spot, Green fluid on the ground under the ski or on the ride plate. It is hard to spot the leak in side the hull with all of the items covering the hose clamps.
    Feb 2010
    So Cal
    4
    Question, I have two SD 2007 RXT's, is there a specific BRP coolant I must use or can I just use a generic automotive type. Thanx for the input.
    Patrick
    Aug 2004
    Olympia, WA
    3,629
    Auto is fine.. I use 50/50 mix
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
  1. 1988 Sea Doo Engine Problem
    By bojoe in forum Sea-Doo
    Last Post: 07-15-2005, 01:32 PM
  2. Sea Doo Engine Paint
    By Dan99XPL in forum Sea-Doo
    Last Post: 06-07-2005, 12:40 PM
  3. Sea Doo engine longevity
    By Dino Doo in forum Sea-Doo
    Last Post: 09-22-2004, 12:57 PM
  4. Sea Doo 951 Silver Engine
    By speedfrk in forum The SBT Experience
    Last Post: 10-20-2003, 05:16 PM
