Re: swap 155hp case for SC case
You pretty much have to change your drive line, the driveshaft from the 185hp will not fit the PTO, let's call it connection to the engine.
You can change the PTO, however I believe that the 185 pump setup is not good for the 215 hp.
The intercooler is in the intake manifold from the 215 hp, that is the black plastic box with the ECU on top, you will see two hose connections facing to the front of the ski.
