Results 1 to 4 of 4
  1. #1
    Thumbs up Servicing the 2 stroke Jet Pump
    Tech Tip of the Week
    Sea-Doo 2 stroke jet pump service
    All of the Sea-Doo jet pumps (except for the 4 stoke models) use gear oil in the jet pump housing to lubricate the bearings that the impeller shaft rides on. The oil in this housing should be changed every season to prevent bearing failure that can cause major damage to the impeller, wear ring and other components. The nose cone of the pump housing can be removed so oil can drain and be inspected for metal shavings and contamination from water. If water is present then the pump needs to be re-built . Water contamination will make the oil look very milky and sludgy. Seals do fail after time and their replacement is considered part of maintenance. Don’t take short cuts on pump servicing - take your time and replace what ever may be in question. Use Sea-Doo approved jet pump oil and re-fill the housing through the Allen screw in the nose cone. Pour slowly so you fill the entire housing. If you have any additional questions on servicing your jet pump, please fell free to contact the SBT tech support.
    Ericka Buczkowski
    SBT
  2. #2
    Joined
    May 2011
    From
    jersey shore
    Posts
    12
    Default Re: Servicing the 2 stroke Jet Pump
    Ericka is there an article on how to rebuild a Kawasaki zxi 1100 jet pump on the site? I also noticed that the nose cone on the original looks like it is too small for my new housing I got from Kawasaki....
    thanx,
    Chris
  3. #3
    Joined
    Mar 2003
    From
    SBT
    Posts
    21,545
    You would have to refer to a factory service manual.
  4. #4
    Joined
    Jul 2013
    From
    NEWYORK
    Posts
    1
    Relativley low cost????????? I bought 2 Carb base plate and a exaust pipe gasket for a 00 XL800 from a Yamaha dealer in South Ga and they were 75.00 !!!!!!! Called another dealer and he wanted more.:( But, Yes, I agree, Dont skimp on the fuel delivery or exaust...
    RABIKA
Thread Information
Users Browsing this Thread
Similar Threads
  1. Jet Pump Servicing
    By thekrust in forum Polaris
    Last Post: 08-01-2007, 06:58 PM
  2. jet pump humming. Bad Bearings?
    By toughwaters in forum Sea-Doo
    Last Post: 06-06-2007, 07:23 PM
  3. Replies: 3
    Last Post: 07-28-2004, 06:31 PM
  4. 1995 750 ZXI Jet pump
    By jsp in forum Kawasaki
    Last Post: 07-08-2004, 10:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
