Has been sitting since 06. Compression is good and everything else is fine. These have the intrigal fuel pum. How reliable are these engines in comparison with the sl 750 and the slx 780. Do I need to convert to premix and should I add an external pump. If so, which pump do I use. Please advice before I do the needed maintenance to get it ready for the summer. Thank you
1996 SLTX 1050 tripple carb
Re: 1996 SLTX 1050 tripple carb
That ski is much better then the old blue fuji motors. Clean out the carbs and if it has gray fuel line replace all of it and run a good 2 stroke oil in it .The oil pumps are reliable no need to remove it.SBT Tech Support is here to help with your problems.
oil pump, cable from carb to oil pump,oil lines and clamps and you may need the oil pump drive part that goes over the flywheel nut if yours does not have the nut with the built in oil pump drive. Oil tank if its not in the ski.SBT Tech Support is here to help with your problems.
Run pre-mix along with the oil injection for the first tank of fuel, this will allow the air bubbles to pass through the lines and the pre-mix will protect the engine while this happens. Run 40:1 mix on the first tank, = 3.2 oz to each gal of fuel.
