I have a 97 gtx. when i first turn it on, even before it starts, a buzzer comes on, but never goes off, even after running for a few minutes. Unfortunately, info center does not work to tell me anything. I have tried disconnecting the temp sensor and oil senesor, but nothing seems to make a difference. Grounding the temp sensor wire turned on a different alarm. I just put in a new SBT engine, and want to fix this before i take it out. A volt check shows that it is charging, voltage is at about 12.9 at 3000 rpm idle.
alarm buzzer
Re: alarm buzzer
Oil, fuel, temp and 12v low are the warning indicators on that ski...
Disconnection the oil sensor will not stop the alarm. The only way to stop that alarm is to put oil in the tank, o remove the sending unit and tie the float up high (to trick it into thinking it's got a full tank). I assume you are going pre-mix?Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
Re: alarm buzzer
12.9 charging.. what's your sitting voltage, nothing on..Dan Solie -
Re: alarm buzzer
The cyl thing spins up the black bar to the top..
Try shorting your sensor wires together, see if that stops the beeping...Dan Solie -
Re: alarm buzzer
i tried spinning the cyl thing at the bootom of the shaft of the oil sensor and it doesnt move. it is fixed and is not supposed to move. i shorted the wires going to the oil sensor and fuel sensor and the buzzer did not turn off....... hmmmmmm....... the buzzing starts out faint and gets louder after a minute or so. but not very loud ever. when i shortded the temp sensor wire a very loud buzzer came on. there was no change in the faint buzzer when i shorted the oil and fuel sensors..... what about the charging system? i had that replace along with the brand new sbt engine at a shop. is 12.9v at 3000rpm idle on trailer ok? would that set off the low 12volt alarm?Last edited by kurtholzbacher; 03-10-2009, 01:42 PM.
Re: alarm buzzer
you might have a faulty buzzer...Dan Solie -
