Hello i just bought a rebuild from sbt this week and i put the motor in my 96 spi. When it came time to put the carb on i noticed that the pulse fitting was in the front by the mag cylinder and on my core it's in the rear pto. My carb is set up to use the rear pto pulse line. Im worried about having to use a longer pulse hose to the carb. I heard that you should not go over 12 inches, im about over that so i don't kink the line. Also the hose barb that is on top of the head which is called the bleed hose i broke that off trying to put a zip tie on there. My question is can i take my core head top and put it on the new sbt engine or will that void the warrenty i would not be taking the cylinder head off just the water jacket, i have a complete gasket kit that i bought so i can put new gaskets in the top. There is not much i can do with the fitting right now.
Mike Alexander
Mike Alexander
