If any of you guys have been reading my previous 3 or 4 threads on my Venture issues , then you know most of the story .. For those of you that don't and might be able to help .. Here goes .. I have a '97 venture 1100 3 cyl .. I rebuilt the pistons rings wrist pins , all with a WSM kit after having the cylinders sleeves cut .. The current compression is 120 psi in all cylinders .. so I know the motor is good .. I have also put in new diaphrams in the carbs , checked pop off (50 psi) and needle + seat's are all clean .. also replaced carb diaphrams .. Cleaned out fuel tank , which was full of junk .. . Replaced all plugs with new ones , cleaned out fuel pump (not real dirty) .. Also checked spark on each cylinder .. it good .. Also while I had the motor opened up , I replaced the 2 blown crank seals and also the magneto seal in front of block ..
Bike starts + runs , just won't get on plane past 5 mph and blows black smoke as well as some blue smoke .. I have adjusted the carbs, and adjusted and adjusted .. still wont go past the 5 mph .. Motor sounds strong .. just can't seem to lay the power down .. Does it sound like carb issue .. cause Ive been thru them a hundred times already .. all clean + look good .
Any body have any idea's that might help me before I decide to torch it with 5 gallons of gas .. VERY , VERY FRUSTRATING ..
Im working on this bike for 4 months (part time)
Thanks in advance for any help ??
