As we all know I'm running on a 185hp ecu with a 215hp motor, I was wondering and would guess what changes I will encounter installing this 215 ecu on my ski, I would expect more fuel, and higher rev limit (maybe 200-300 +) anything else or am I wrong on my guesses? Could ignition timing be one?
ECU 185hp vs 215hp
Re: ECU 185hp vs 215hp
Yup, fuel maps, R/L and timing and security are the main functions of the ECU. You wouldn't necessarily get more fuel because your ECU has no clue what # injectors you are running, but you will get a different fuel / air mapping setup fuel map. This will probably result in you using more fuel because now the ECU can detect the increased AF of the SC.Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
In your other thread the difference in rev limit has been explained to you to help you determ if it made sence to run a 185 ECU on a 215 hp engine setup. Look back in your other thread and you will find it.
Also there is a difference between a 2003 185 ECU and for example a 2005 215 ECU in handling your oil pressure signal.
As you said before your ski runs fine on the 185 ECU from which I think reading all of your posts is a 2003 ECU, the 215 ECU (2005 reading your posts) will give you an oil error since the oil pressure sensor works different for both ECU's.
so what is needed is an oil pressure sensor that matches the 2003 and one that matches the 2005?
If so then that is not making sense, I am running a 2005 engine (complete) except the ecu, so that means I am running the 2005 oil pressure on the 2003 ecu and it runs great with a 2-3mph gain, no error. I will be putting the 2005 ecu on the complete 2005 engine soon, so no chance for an error which I don't get one now.Last edited by nazrin; 05-04-2009, 09:24 PM.
Originally posted by nazrin View PostI'll post it for more ref. 185hp ecu has a 7650 rev. limit. The 215hp ecu has a 8200 rev. limit.
That's almost one extra full impeller rotation per tenth of a sec. That should be very noticeable.
Only if your boat hits the rev limit (which it shouldn't) would you notice the difference. Now, with a higher R/L, you can start to play with impellers etc and get more out of the boat, but you might suffer in the bottom end dept. or, vice versa..Dan Solie -
Dan Solie -
sweet! Let us know how she runs now.Dan Solie -
I dont think you will see any error on the oil pressure sensor, the oiling systems are the same and the late model part is the same for early model, the sensors are Not differentSBT Tech Support is here to help with your problems.
Skisol, you can't even interchange the 06 ecu with the 05 and back ecu, they are totally different. The 06 and up ecu gets coded to the gauge cluster and runs a complete different wire harness.SBT Tech Support is here to help with your problems.
Ok, here is the deal, I'm stumped
As I had posted I put in a 50hr 2005 engine in my 2003 GTX and was running my 2003 ecu on the 05 motor, I didn't have the 05 ecu at the time.
I posted my 185hp GTX did a top speed of 65/66 or so, my 05 motor in my GTX with the 03 ecu did a top speed of 67/68 or so.
I just received my 05 ecu and popped it in did a test run and notice my rpm max was about 7500 and only was able to top it out at 65 down wind, did another test run and was only able to top it out at 63.
What is the deal? So I popped in my 03 ecu and did a down wind run and believe it or not I saw the digital flick to 69mph. What is wrong with this 05 ECU, it is rubber stamped 637 1204, I was told it was a 05 RPX ecu
here is what is stamped on it
MSE 3.7 R / A1
664 961
412.252 001/021
FD 20 12 04 0042
K02 H02 S02
What do I have????
also this 05 ecu flashes MAINT in the beginning of the boot, will that limit it? AND, AND, I did notice that about at a constant 30mph the engine didn't sound as smooth as the 03 ecu installed.Last edited by nazrin; 05-17-2009, 06:31 PM.
