Results 1 to 3 of 3
    Jun 2005
    florida
    65
    Default Honda AquaTrax R-12X Turbo
    I have a 2003 Honda AquaTrax R-12X Turbo, put in the lake, fired right up, started to ride toward the other end of the lake the heat warning light came on the FI light started flashing and then the engine shut down. Engine cooled down and the same thing happen again. No water in the oil. No debrie in the jet intake. Friend has the same ski and swapped the sensor because he stated that is a common problem with the Hondas. No change, still did the samething. Any suggestions?
    21,545
    Default Re: Honda AquaTrax R-12X Turbo
    Use an air compressor and blow out the cooling lines from the engine back to the pump.
    Jun 2005
    florida
    65
    Thanks for the info. It worked! Appreciate the help.
    Question:
    Is there any type of solution that I can use to flush out the water flow system that will clean any crudd that may be left in there?
    I have a bottle system for my SeaDoo RXP SC that connects to the hose and I use it to flush out the water system after running it in the salt water. I just add the solution in the bottle and run the ski to clean the system from salt.
  1. 2003 Honda R-12X Turbo vacumm valve
    By 8kgold69 in forum Honda
    Last Post: 04-24-2009, 09:29 AM
  2. honda aquatrax
    By gen2seedoo in forum Sea-Doo
    Last Post: 11-03-2007, 09:10 AM
  3. 2002 Honda Aquatrax F12X turbo
    By YamaHP in forum PWC's For Sale
    Last Post: 10-26-2005, 02:08 PM
