Results 1 to 2 of 2
    Jun 2005
    florida
    65
    Default Changing the driveshaft bearing housing on a 2003 Honda Aqua Trac R-12X
    How hard is it to change the driveshaft bearing housing assembly on a 2003 Honda R-12X turbo. There is a rubber hose that runs from the grease fitting down to the housing and where the grease fitting goes into the housing, it leaks water and almost caused the ski to sink. Any suggestion, help? I do a lot of my own mechanical work. I have restored several classic Corvettes so I am pretty mechanically incline.
    thanks
    Barry
    21,545
    Default Re: Changing the driveshaft bearing housing on a 2003 Honda Aqua Trac R-12X
    Get the factory manual it will explain how to remove the jet pump and drive shaft then the seal assembly.
