Yes, the same bogging Raider. AKA (Zoolander) can't turn Left, ski. After checking everything and I mean alot of stuff:
Pulled engine, replaced lower seal
Carb inspection twice
lines blown out
new fuel filter
bypassed reserve switch
engine compression 130 and holding on all three
new fuel
rebuilt fuel pump
took off Riva Air filters, replaced with orig Yamaha
restricted return line to gas tank
This ski still blogs out when it jumps around, worse on the left turn, unless you keep and let it over 3/4 throttle n the turn.
When I decided to bypass the reserve on / off switch, I kept the engine hood open, to see if it was pulling fuel into the filter before I took it out on the river and might have realized I had hooked it up wrong. I noticed that the filter filled up with 3/4 air. The only other thing different about this ski is that the owner before me put a primer system in place of the choke. Could this primer be letting air into the system?
lines blown out
new fuel filter
new fuel
rebuilt fuel pump
