96 blaster wont crank over??
  • 96 blaster wont crank over??
    hey whats up.
    ok my blaster will not crank over.
    i hit the start button and all you hear is a click coming from the electrical box. Im guessing that is the starting solenoid that makes the click.
    but starter does not rotate.
    Voltage on battery does not drop when i hit start button and when click occurs.
    My motor rotates because i can rotate it by hand no problem.
    I havent ran the ski in about 3 years. last time i ran it. It started right up no problem and ran great. Although impeller did seize on housing.
    I now have new shaft, housings, impeller. NOT installed yet. i want to make sure motor cranks over first.
    I preserved the motor while it was sitting to ensure no rust build up or anything.
    So what can it be guys?? please help.
    Re: 96 blaster wont crank over??
    With the spark plugs removed, try to crank it. Check voltage at the starter while cranking, if you have 10.5 or higher, than the starter should turn over. If the starter will not turn over with the 10.5 or higher voltage and the engine can be rotated by hand then the starter may be shot.
