I have a 95 760 that starts quite easily. However, after starting, it may take 3 to 5 minutes to get going. As soon as the throttle is squeezed, it dies. Starts right back up and will maybe achieve a little higher rpm then dies again. This goes on and on and on. Finally after probably 20 attempts, it will take off and run like a champ...UNTIL you slow down to an idle and then you have to start the whole process over again. My 95 1100 will act the same way once in a while but the 760 does it every time. Any suggestions?
Thanks!
Thanks!
