Hi All,
I've got a 1200 motor (non pv) that I'm having some issues with. I pulled the plugs to do a compression check and noticed a lot of oil visible on the surfaces of the pistons. If I stick a rope into the cylinder it comes out covered in yamalube. When cranking the engine without the plugs oil comes out (not a huge amount, but enough to make a mess). Compression reads 120 across all 3 (other engine reads 90, it is a LS2000). The next day after doing this I checked the hull and had some oil pooling in the bottom. I traced it up to the engine and it looks like it might be coming from the rear seal area. Any ideas?
Thanks!
Adam
1999 LS2000
Thanks!
Adam
1999 LS2000
