i have a 1997 gts the motor will not crank with the plugs in take them out it cranks just ordered new starter could this be another problem besides a weak starter it has a new battery motor is also hard to turn by hand. the motor is only 1 yr old is a reman from sbt any help apriciated
starting
Re: starting
motor is hard to turn by hand with, or without the plugs in?
Most likely it's your starter, but, take the time and inspect your power and ground cables at teh starter end, solenoid connection and battery end. Peel back a little of the wire cover and see if its rusted. If it is, replace.Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
Re: starting
The motor should be fairly easy to turn by hand with the plugs out. You will feel the compression stroke and it will get a little tight, but then release and be easy for another 1/2 revolution or so...
If it's tough to turn with the plugs out, pull the pump and try turning it again. You may have some binding in the pump bearings... or.. a problem with the motor.Dan Solie -
Re: starting
we got the starter instaled it works good but after the starter went out we left the seado in the water at the river it took on water about 2 inches over the battery it cranks good but no spark any ideas i am asuming somthing in the electric box is shorted out
Re: starting
open up your electrical boxes see if there is water in there. If so, dry it out.Dan Solie -
Re: starting
download the manual and perform the VTS testing functions with a multi-meter
www.seadoomanuals.netDan Solie -
Re: starting
ok i took the bike to the local motorsport shop they seem to think water got into the motor i know the water was about 2 inches above the battery the compresion is130 on the front cylender and 108 on the rear the motor is tight they say they can hear a scratching sound does that sound like the motor is shot hhe didnt go any farther to see why it wasnt getting any fire
Re: starting
130/108 will still run, but run poorly...
How do you KNOW it's not getting spark. Have you grounded the plugs and visually watched the plugs NOT fire?Dan Solie -
Re: starting
yes we grounded the plug also the motorsport shop said the spark is not consistant it sparks every once in a while water was aprox. 2-3 inches over the batt. could water get into the cylender thy seem to think the low compresion is from posible water
Re: starting
Water in the cyl will not kill spark.. Water in the FRONT cover will...
Time to open the mag cover.Dan Solie -
Re: starting
yes i realize that what they was telling ne is that they didnt know if i wanted them to check out the spark problem any farther if the motor is shot they think maybe water may have got into the rear cylender it has a grinding sound .sorry i didnt explain better
Re: starting
pull the head yourself.. Only takes a couple of minutes. Take a look at the pistons and let us know what you see.Dan Solie -
Re: starting
i have a 1998 seadoo gtx,rfi engine hard to crank with sparkplugs in. take them out it cranks o.k, battery,power and ground cable checked and ok. the starter cranks the engine about 2 sec and then it release!!!!! any help ?
