no spark sometimes on a 2001 polaris
  • no spark sometimes on a 2001 polaris
    i have a 2001 polaris SLH. i get spark the first time i start it up. it run good to. once i turn it off and try to restart it i get no spark. i replace the coil. if i disconnect the battery and then connect it and try to start it, it starts and runs good. but as once i turn it off i loose spark and it will not start. intill i disconnect the battery. what do u think it is or is there a test i can do to find out.
    Re: no spark sometimes on a 2001 polaris
    Its a cdi issue or a start/stop rectifier.
      make sure you have a min. of 10.5 volts while cranking, if not you will not have spark.
        Very true.
