ordered needle & seat from sbt to install in carbs since i had problem with them after rebuilding. and did not replace during rebuild. recived N&S and started to install and the hold down plate would not fit around the top of seat. so i called sbt tech and after a couple days checking in to it and sending pic of orig. old & new N&S side by side showing the differances and that i had not ordered the wrong parts and tech decided it had been packaged wrong. sent me proper new ones promptly. Thanks shirt size XL
96 speedster twin 717 twin mikuni carbs pump built in mag carb
now installing these n&s in mag carb as i test pop off presure the n&s starts leaking @ 22 psi before pop off @ 26 psi fell to 20 psi and slowly leaks down form there to approx 11 psi. is this a problem? if so what to do?
also pto carb pop off @ 25 psi drop to 20 psi and also seems to be leaking around N&S but slower.
