My starter bendix engages the flywheel and spins the gear not the flywheel. Is there a key in the flywheel for the gear as well as the flywheel?
flywheel starter gear 96 760
Re: flywheel starter gear 96 760
Thank you. The flywheel key is fine. The flywheel does not move on the crankshaft. The GEAR on the flywheel is rotating thereby not turning the flywheel. Is the gear on the flywheel engaged by a clutch or magnetic means or just physically attached to it so that the engine will crank?
