1100 zxi oil block off question??
  • 1100 zxi oil block off question??
    Hi, I'm going to block off my oil pump feed hole and was wondering if oil must be put into the casing inside the front of the motor where the oil pump bolts onto. There is a plastic plug like thing(like oil filler plug) screwd into the top of the casing. cheers
    Re: 1100 zxi oil block off question??
    No oil in the front cover the cap is for timing inspection only.
      How do you no if there is a block off ? It looks totaly dri inside. Should i run oil in pump & gas ? Also i have a big pool will hert the pool h20 if i run it in pool for 4 or 5 min.? Thanks any input.
        You can pre mix your oil and gas to 40:1 = 3.2oz of oil to every 1 gal of fuel. Dont think I would test my ski in my pool.
