Every other day plugs are fouled with oil,cannot start! After cleaning or replacing,cold engine starts without using choke.Always had to use choke prior to this fouling problem.
1998 seadoo GTI
You have either leaky needles and seats or you have a case seal going bad leaking oil into the cases from the rotary valve cavity. You better hope it is the needles leaking, or you will need to rebuild the motor.Bill O'Neal WCM
