I have a 94 Polaris 600 xlt light weight triplle, It is a bit hard to start and it bogs until the R's are up to about 2000. It has a 5000 clutch and is also piped. it has Mikuni carbs. after it reaches the proper rpm it takes off great. I think it may be too lean. Is this correct and how would you richen the low speed accelleration. Is there and accellerator pump on these carbs? It is not the clutch because it bogs without the belt even close to being engaged. Thanks for your help in advance.
94 polaris sled 600 xlt bogs from line
