Kawasaki winterizing
  • Kawasaki winterizing
    How do you winterize a 2007 ultra lx jt 1500? does it need antifreeze?
    Re: Kawasaki winterizing
    Any water in the cylinders will drain on its own, You should put fuel stabilizer in the gas tank and remove the battery for the winter. Use a 1.5 or at max a 2.0 battery tender to keep a good charge in the battery over the winter.
      well does the kawasaki 4 strike need antifreeze for winterizing?
