Results 1 to 8 of 8
    Jan 2010
    Little Rock, AR
    3
    Default Max Bore size: 00 Ultra 150
    So with SBT sleeved cylinders, what is the maximum bore size you can go without working heads or other major engine work?
    I'm looking at boring the cylinders as they are scored, and I'm hoping to avoid a resleeve.
    21,555
    Default Re: Max Bore size: 00 Ultra 150
    The size that we bore the sleeves are the same as the stock O.e. bore, we dont offer any other size piston.
    Jan 2010
    Little Rock, AR
    3
    I guess then, that you guys don't have any recommendations then on how much you can bore out sleeved cylinders? Stock and that's it?
    21,555
    You might be able to find a piston from wiseco that could work but I couldn't tell ya what it would be from, If you do find something dont bore past 0.5 and you will not have to mess with opening the heads up.
    Aug 2001
    Las Vegas, Nevada
    1,220
    Quote Originally Posted by Technical Support View Post
    You might be able to find a piston from wiseco that could work but I couldn't tell ya what it would be from, If you do find something dont bore past .50 and you will not have to mess with opening the heads up.
    Why does the website offer the piston in both STD and 0.5mm sizes? http://www.sbtontheweb.com/Merchant2...roduct_Count=6
    John Kubiak
    Las Vegas, Nevada
    Sea-Doo Tech 13736
    21,555
    John your correct, Its not listed in my shop book. If it needs to be ordered sales may need to find the part # online.
    Jan 2010
    Little Rock, AR
    3
    Huh. When I shop by model (2000 Ultra 150) I don't see the oversize piston KIT available:
    http://www.sbtontheweb.com/Merchant2...roduct_Count=4
  8. #8
    Post Re: Max Bore size: 00 Ultra 150
    Try now, missing 1 little piece of information.
    Ericka Buczkowski
  1. Where to buy a ultra 150?
    By David McLaurin in forum Kawasaki
    Last Post: 04-11-2008, 07:25 AM
  2. Ultra 150..Maybe a broken headgasket???
    By Bang in forum Kawasaki
    Last Post: 07-24-2007, 09:25 PM
  3. Piston size vs. Bore size?
    By Dragracer55 in forum Sea-Doo
    Last Post: 07-27-2006, 08:27 AM
  4. 2000 Ultra 150, # 2 Cylinder Dead
    By pav in forum Kawasaki
    Last Post: 07-08-2005, 12:30 AM
  5. 1st over bore size and head issue????
    By 97GSX in forum Sea-Doo
    Last Post: 10-20-2003, 05:55 PM
