1996 polaris sl700
  • 1996 polaris sl700
    i have a 1996 polaris sl 700. i'm having a problem with the machine constantly shutting down. if you wait a minute it will restart and run and then die again after a few minutes of riding. does anyone have any ideas? also does anyone know where i can purchase a new cdi box? i should note that i rebuilt both carbs, replaced a faulty rubber hose from the exhaust manifold to the water box, cleaned everything on the motor itself, replaced all of the fuel lines and filters, installed all new gaskets on the motor etc. any answers would be greatly appreciated.
    Re: 1996 polaris sl700
    Kit part number- 2873355 is the complete ignition update kit. Sounds like a C.d.i issue, polaris had problems with the early 700 and 1050 ignitions. Call Watercraft superstore at this number and they will help you get the Kit. Don't just buy the C.d.i, in the long run the kit is cheaper and replaces all the old weak parts.
