Virage not running
  • Virage not running
    i STARTED MY SKI (2000 VIRAGE) WITH NO PROBLEMS AT HOME, THEN WHEN I GOT IN THE WATER AFTER AN HOUR DRIVE IT WAS VERY SLUGGISH, AND WAS HARD TO START. SEVERAL TIMES THROUGHOUT THE DAY IT WOULD RUN GOOD, BUT I MADE A HARD TURN IN THE WATER ONCE AND AFTER THAT IT NEVER WOULD DO MUCH MORE THAN IDLE. I KEPT CHECKING UNDER THE SEAT TO MAKE SURE EVEYTHING WAS RIGHT, AND AT FIRST DIDNT NOTICE THE SPARK PLUG WIRE OFF THE PLUG. I CHANGED THE PLUG, FIXED THE WIRE BACK, BUT THE SKI WILL STILL NOT RUN! i NEED HELP IN KNOWING WHAT IS OR MAY BE THE PROBLEM
    Re: Virage not running
    Battery cranking voltage MUST BE NO LESS then 10.5 volts this is very critical. If the fuel is more than 3 months old its no good unless stabil was added when the fuel was fresh, If the ski has gray fuel line on it I would suggest rebuilding the carb and replacing the gray lines.
