Tigershark minimal propulsion at full throttle.
  • Tigershark minimal propulsion at full throttle.
    At full throttle ski has minimal forward propulsion. Reverse however works as it should. Any suggestions?? Has happened about three times now. No ryme or reason. Next time I launch it may run fine. Any suggestions or help would be greatly appreciated. Thanks!
    Re: Tigershark minimal propulsion at full throttle.
    Cavitation issue, check to see if the ride plate is sealing tight to the hull, you may be sucking air into the pump.
      What model shark is it? Does it get worse the longer you ride it or does it cavitate as soon as you get in the water and take off? Is there any water in the hull
