Results 1 to 3 of 3
    May 2010
    Spain
    6
    Default xl 760 dies at longer idling
    Hi my xl 760 idles at approx. 1300 but when idling for a few minutes rpm goes down and engine nearly dies. When i thottle up it takes time til the engine responses. Any idea how to solve that problem?
    Thanks,
    Michael
    May 2010
    Shreveport,La
    21
    Default Re: xl 760 dies at longer idling
    I had the same problem on the same machine. Removed the carbs had them rebuilt at a local shop and put them back on. Runs much better now. Also do not run cheap gas ie gas with ethanol. It will eat away at the rubber in the fuel lines and in the carbs. Good luck.
    May 2010
    Spain
    6
    Thanks for your reply.
    Am using 98 and carbs are rebuilt using stock settings.
    Is the engine too rich or troo lean when this happens? What else can I do to get rid of the symptoms.
  1. 95 Waveraider 760
    By gwag1 in forum Yamaha
    Last Post: 08-06-2009, 08:46 AM
  2. 96 Yamaha 1100 dies
    By dollison in forum Yamaha
    Last Post: 06-04-2007, 09:22 AM
  3. dies after idling too long on new engine
    By radiocontrolhead in forum Sea-Doo
    Last Post: 09-25-2005, 11:21 AM
  4. 97 760 Venture loss of power
    By Joepenske in forum Yamaha
    Last Post: 09-06-2005, 04:38 PM
  5. 95 XP Just dies...
    By skyrat in forum Sea-Doo
    Last Post: 10-08-2004, 09:59 PM
