Results 1 to 4 of 4
    Mar 2001
    60 miles south of New Orleans
    36
    Default
    I've seen the technical data on the additional fuel pump. Can you give me some details? What come in the kit?
    "We sell fuel pump kits for $40."
    Feb 2001
    Clearwater, FL
    7,358
    Default
    The kit comes with an external pump, t-fittings, clamps and hoses. Everything you need to plum into your fuel lines and run the additional pump in.
    Apr 2001
    Dallas, TX
    305
    Default
    I'm new to PWC / marine engines, and have just purchased a '95 Polaris SL750 that had a SBT installed in October of last year, along with the secondary fuel pump kit.
    A: They have not had any jetting or adjusting done after the second pump / motor was installed, so I'm curious if there is any major changes needed there.. beyond the std outlined carb adjustment article?
    Given that this is getting older (95), I'm going to replace the rubber lines around the boat; fuel, air, etc. and rebuilding the carbs while I am running around in there.
    B: Is there a specific requirement for marine 1/4" fuel line or should I be ok with std automotive type lines?
    C: Can you think of anything that would be generally worn out on a '95 that I should maint while at it?
    Thanks so much,
    -Eric
    Apr 2001
    Dallas, TX
    305
    Default
    Bryan,
    What are the silver rectangular pumps rated at for flow/pressure?
    Thanks,
    -SEF
    [sorry, found this information later]
    Mikuni Rectangular [#DF44-211-D]
    Flows 14 LPH
    Mikuni Circular 2 outlet [#DF52-21-D & DF52-73]
    Flows 35 LPH
    Mikuni Circular 3 outlet [#DF52-92]
    Flows 35 LPH
    Mikuni Pentagonal 2 outlet [#DF62-702]
    Flows 65 LPH
    [ April 10, 2001: Message edited by: Skexies ]
  1. Polaris jet pump kit question
    By TandD023 in forum Polaris
    Last Post: 06-16-2007, 02:47 AM
  2. Polaris SL 750 Jet Pump Rebuild Kit ??
    By dierdorf in forum Polaris
    Last Post: 03-04-2006, 10:51 PM
  3. Replies: 3
    Last Post: 08-30-2005, 08:11 AM
  4. fuel pump theory
    By addicted in forum Polaris
    Last Post: 08-11-2005, 12:16 PM
  5. installed sbt 2nd. polaris fuel pump kit, now idle changes
    By johnd in forum Questions about SBT
    Last Post: 07-20-2001, 12:22 AM
