I have a 96 Kawasaki 750 STS that I'm having issues with. It seems to only reach 6000 RPM's and if you try to increase the throttle anymore past 6000 it bogs down. Also when trying to take off from idle if you dont feather the throttle it bogs also.
I rebuilt the carbs and checked the compression (115 each cylinder). When you pull the plugs they're both wet. I have noticed when I pull the plug wire off the spark plug and ground the wire I do get spark but it seems really weak?
Can anybody give me some ideas before I just start throwing parts at this thing?
I'm contemplating putting on a new coil but just want to see if I'm even heading in the right direction.
Any help would be appreciated!! :)
