My waverunner was running great then all of a sudden it stalled then went 50 ft then stalled . kept doing that. I took comp. test and the rear cylinder is 0 and the front has 150 could something be stuck open???
2000 xl700
Re: 2000 xl700
Time to take off the cylinder if your crank is OK get a top end overhual if not get an engine. But you need to rebuild your carbs pay attention to jet screw settings. Before taking them out screw each one high side and low side in counting the number of turns.
OEM stteing for your 62T are
Front high 5/8 + - 1/4 rear high 1 1/8 + - 1/4
Low side front 5/8 rear low 5/8 + - 1/4
