How long can i leave the engine running with a hose pumping water through the engine. I know that your start the pwc before you have the water turned on, but how long can i leave it running?
How long can your run a TS770 DRYDOCK?
Re: How long can your run a TS770 DRYDOCK?
You should limit on land with the hose attached type running to no longer than 3-5 min.SBT Tech Support is here to help with your problems.
