'01 Ultra 150 oil Injection removal
  • '01 Ultra 150 oil Injection removal
    I would like to remove oil injection...does anyone know what the oil levels need to be in front and rear cover? I heard I need to run a line between two nipples, but before I do that that I can fill the front and rear covers so bearings will be lubricated.
    Thanks!
    Mike
    Re: '01 Ultra 150 oil Injection removal
    The ultra 150 needs major modifications done to the inside of the crank case to run a pre-mix system. It is not recommended for the average guy to take on as a project.
      I am a technician, this is my personal ski. I've been told that as long as the counter bearings have sufficient oil, that I can attach a line from front to back fitting...what else would need to be done...I've already disabled my pump...so at this point I need to go ahead with it. thanks for any help you may be able to give me.
