I have a 1996 polaris sl700, and the ski will not get up to full power. When you have it at full throttle it barely goes. It seems like its stuck in limp mode. This all started when i rode for about a half hour, stopped to take a break, shut the fuel off, then got ready to leave again is when this problem started. Any ideas?
1996 polaris sl 700
Re: 1996 polaris sl 700
Check for spark on both cylinders. If you have good spark then clean the internal filters in the carbs and if the ski has gray fuel lines then replace all the gray lines with new fuel line.SBT Tech Support is here to help with your problems.
