gas mix
  • gas mix
    what should i mix my gas on the 717 motor thanks
    Re: gas mix
    i run my premix 40 to 1 with out problems use good oil, not walmart penzoil
    94 gtx, 96XP, 97XP,04 GTC SC,05 RXT & RXP
      Re: gas mix
      what oil do you use i am usein lucas is that good stuff
        Re: gas mix
        I prefer seadoo oil, or Amsoil in all my ski's..
        Dan Solie -
        04 RXP (the "Instigator")
        94 xp (freestyle mods)
        95 xp (faster than the 94)
          Re: gas mix
          I use Motul 800, That's what I run in my racing bike and it burns clean.
            Re: gas mix
            So I am thinking about using AMSOil, can you really get the 100 to 1 and cut the amount in half and it works as good as yamalube? Have a 94 Waverunner 3 and just put a rebuilt block into a 99 Waverunner 760. Thx
              Re: gas mix
              no... even with Amsoil, you need to run a consistent 40:1... Some people I know run 60:1 and seems to run fine, but I like to error on the side of caution
              Dan Solie -
                Re: gas mix
                i cant find a chart to explain the ratio, is ratio 40. 1 4 ounces of oil to 1 gallon of fuel? if not show me the mix chart please. my 787 oil pump is bad i plan on leaving it hooked up as stock, just to keep the roter bathed , and will be pre mixing fuel , should be ok?
                  Re: gas mix
                  40.1 meaning 4 ounces of oil to 1 gallon of fuel thanks again
                    Re: gas mix
                    3.2oz of oil : 1 gallon is 40:1
                    or
                    16oz oil : 5 gallons
                    Yes, you can leave the pump hooked up, but you need to remove the pump drive shaft.
                    Dan Solie -
                      Re: gas mix
                      thanks bunch dsolie cya skipper out
