99 genesis out of idea's
  • 99 genesis out of idea's
    runs great up to 40 mph then it won't go any faster surges from 5000 to 6000 rpm's. It is fuel injected. Replaced stator and fly wheel. compression good, fuel pressure good tps checks ok. Plug wires and coil pack resistance good no exsaust leaks. Impeller clearance good. Fuel filter good, cleaned and checked injectors. Reed valves ok .Removed tan wire no differance don't get it comes out of hole great no top end. Out of ideas need somthing new. got to be somthing I'am missing help
    Re: 99 genesis out of idea's
    Has the impeller been changed to a different one? or you may a bad exhaust baffle and its restricting the exhaust flow.
      Impeller looks good and clearence aroud housing good exhaust I'll check
        Are exhaust baffles in the silencer?
          Yes, and they can melt causing exhaust back -up choking out the engine.
            unhooked exhaust hose still only 4500 rpm's
              The flywheel key may have broke and is throwing off the timing or has pushed out when you replaced the stater. Check the key.
                Has a ne fly wheel and stator.
                  Yes but check the key, if you didn't tighten the flywheel properly it could sheer the key.
                    Also check the water flow tube that goes through the computer, it keeps it cool and if it over heats it will limit rpms
