Results 1 to 4 of 4
    Jul 2010
    Fuquay Varina, NC
    5
    Default I just purchased a new SBT engine. DUring the break in procedure...
    the engine would not restart after running for the first 30mins. Everything turns over but its not starting up. For the break in i'm using a 32:1 mixture and following the recommended break in procedure as SBT recommends. The carb is brand new, and all fuel lines, filter, and selector valve have been replaced. When I take the plugs out the plugs are wet with fuel.... I have spark with "checked with an inline spark checker" each plug. Checked voltage @ battery while cranking and every thing reads fine.
    Compression is good.
    I have no idea what the prob is or maybe I'm just overlooking something simple. I just don't understand why it doesn't start. WHen I originally started it, it fired right up...
    I'm sure I have fouled plugs but I did put in a new set and nothing...
    21,545
    Default Re: I just purchased a new SBT engine. DUring the break in procedure...
    What engine do you have?
    Jul 2010
    Fuquay Varina, NC
    5
    Yamaha 650
    Jul 2010
    Fuquay Varina, NC
    5
    I just called SBT, just waiting on a call back. So far everyone there has been very friendly!
  1. Break-in procedure
    By pttsbrghfan in forum Yamaha
    Last Post: 08-08-2006, 02:37 PM
  2. SBT New Motor Break In Procedure? 1999 GTX LTD
    By CG1999GTXLTD in forum Sea-Doo
    Last Post: 09-10-2004, 07:15 PM
  3. purchased 1st Jet Ski 95 sl750 need help or something
    By topwaterkeeper in forum Polaris
    Last Post: 08-13-2004, 07:02 PM
  4. purchased parts
    By davetammy in forum The SBT Experience
    Last Post: 08-22-2001, 03:18 PM
  5. PURCHASED A REBUILT SEA-DOO ENGINE
    By pklaus in forum The SBT Experience
    Last Post: 05-31-2001, 01:49 PM
