93 tigershark 640 engine installation question
  • 93 tigershark 640 engine installation question
    I am installing an engine 640 into a Tigershark. There is a spacer washer that goes between the coupler and the engine on the crank. I am missing it. Is this a special washer or will a stainless washer due. Can I order it from somewhere if it is special? This is holding up the job.The engine has a larger drive shaft than the original engine. I have a larger coupler but am concerned that it screws in to deep on the crank and does not stay flush.
    Re: 93 tigershark 640 engine installation question
    Search Babbits on line and look at the diagrams, this should help you and they can get the parts for you.
