is it ok to use amsoil marine gear oil in the jet pump or is there another amsoil fluid that i can use instead of the seadoo oil for my 2000 xp
jet pump oil
Re: jet pump oil
I am also an amsoil dealer and a few years ago I ran the marine gear oil.. The bearings overheated...
I am a firm believer of not using overpriced seadoo oil whenever possible, but when it comes to the pump, I always use the SD stuff...Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
Re: jet pump oil
marine gear oil... but as I said, it burned up the pump...
now, if you are talking about the OIL PUMP (not the jet pump), then interceptor all the way!Dan Solie -
Re: jet pump oil
Until it's full, then, shake it, add some more, shake it, add some more.Dan Solie -
Re: jet pump oil
INTERCEPTOR™ High Performance Synthetic 2-Cycle Oil (AIT)
A high-performance two-cycle oil with a performance emphasis on exhaust power valves. Excellent for all types of snowmobiles, motorcycles, personal watercraft, ATVs and jet boats. Contains high levels of detergent additives to prevent valve sticking. High quality replacement for manufacturer branded oils. Injector use or 50:1 premix. JASO FC, API TC
Package sizes include:1-Quart Bottle
1-Quart Bottles (case of 12)
1-Gallon Bottle
1-Gallon Bottles (case of 4)
16-Gallon Keg
30-Gallon Drum
55-Gallon Drum
AMSOIL INTERCEPTOR™ Synthetic 2-Cycle Oil is formulated with a proprietary blend of the finest synthetic base oils and additives available today. This unique AMSOIL Chemistry represents a breakthrough development in the field of two-cycle engine lubrication. The backbone of AMSOIL INTERCEPTOR 2-Cycle Oil is a specially developed molecularly saturated synthetic base oil. This, combined with a robust additive package, ensures exceptional lubricity, cleanliness and optimum clean-burning characteristics. Extensive research and testing, including a full snowmobiling season in severe Rocky Mountain applications, has proven that wear on cylinders, pistons and bearings is significantly reduced. And with up to 30 percent more detergency and dispersancy additives than typical two-cycle oils, AMSOIL INTERCEPTOR virtually eliminates hard carbon deposits that cause exhaust power valve sticking, ring sticking and preignition-promoting "hot spots" in the combustion chamber.
- Helps prevents hard carbon deposits that cause exhaust power valve sticking and ring sticking.
- Superior lubricity controls cylinder, piston and bearing wear.
- Reduces smoke and odor associated with two-cycle engines.
- Helps prevent plug fouling.
- Provides exceptional SAE #4 cold temperature fluidity (-58°F pour point).
- Versatile and excellent for all types of recreational equipment.
- Protects against rust.
- Helps prevent pre-detonation from combustion chamber "hot spots."PRODUCT DESCRIPTION
AMSOIL INTERCEPTOR Synthetic 2-Cycle Oil is formulated with a proprietary blend of the finest synthetic base oils and additives available today. This unique AMSOIL chemistry represents a breakthrough development in the field of two-cycle engine lubrication.The backbone of AMSOIL INTERCEPTOR 2-Cycle Oil is a specially developed molecularly saturated synthetic base oil. This, combined with a potent additive package, ensures exceptional lubricity, cleanliness and optimum clean-burning characteristics. Extensive research and testing, including a full snowmobiling season in severe Rocky Mountain applications, has proven that wear on cylinders, pistons and bearings is dramatically reduced. And with up to 30 percent more detergency and dispersancy than typical two-cycle oils, AMSOIL INTERCEPTOR virtually eliminates damaging deposits on piston skirts, ring grooves and exhaust power valves.APPLICATIONS
AMSOIL INTERCEPTOR Synthetic 2-Cycle Oil is recommended as an injector oil or at a 50:1 mix ratio in carbureted, electronic fuel Injected (EFI) and direct fuel injected (DFI) snowmobiles, personal watercraft, motorcycles, ATVs and jet boats, including, but not limited to, those manufactured by Bombardier®, Yamaha®, Arctic Cat®, Polaris®, Kawasaki®, Suzuki® and Honda®.It is recommended wherever JASO FC or API TC two-cycle oils are specified. INTERCEPTOR is a premium quality replacement for recreational equipment manufacturers' branded two-cycle oils. It is compatible with most mineral and synthetic two-cycle oils, however, for best performance, mixing oils should be minimized.400,000 Miles of Severe Snowmobile Field testing With No Deposit Buildup, Power Valve Sticking, Ring Sticking or Engine Failures.
Subjected to adverse field testing conditions in the Rocky Mountains, including long trail rides, high RPM powder riding and steep hill climbs, AMSOIL INTERCEPTOR demonstrated superior wear protection and outstanding deposit control.
**I know I'm a little late but isn't Yellow a great color? If you have future questions or concerns let me know i will be happy to assist you.
David Vain
(512) 309-4833 TX
(985) 788-0554 LA
info@naso72.com
www.naso72.com
AMSOIL Regency Direct Jobber
Re: jet pump oil
David.... You are not suggesting to this person that he ads Interceptor to his PUMP GEAR OIL are you?!?! That probably wouldn't be wise.Dan Solie -
Re: jet pump oil
Dsolie
You are absolutely correct that I'm not suggesting using the Interceptor Oil. We do not have any product that is compatible for the "Jet Pump. This information was posted so 2000XP can read the latest updated information on this product he is currently using."i already run the interceptor oil and it works great". ". I appreciate your heads up so as not to cause any confusion in regards to this.David Vain
(512) 309-4833 TX
(985) 788-0554 LA
info@naso72.com
www.naso72.com
Re: jet pump oil
No problem David.. Just wanted to be clear.. I am also an Amsoil fan and run AIT in all my 2-strokes, as well as all my vehicles. Used to be a dealer, until this year.Dan Solie -
Re: jet pump oil
What happened to your Dealership? If it is worth anything to you I allow everyone to acquire the products at Wholesale. I work strictly off commission which helps everyone out especially in today's economy. I attached the prices for AIT for you so you can refer to it but as you know there is shipping charges and tax but it is still a good deal. Let me know if you are interested. Once again i appreciate your input.
Wholesale MSRP
AITQT -EA 1 Quart $7.35 $9.50
AITQT -CA 12 Quarts $83.55 $112.80
AIT1G -EA 1 Gallon $28.85 $37.50
AIT1G -CA 4 Gallons $109.80 $148.25David Vain
(512) 309-4833 TX
(985) 788-0554 LA
info@naso72.com
www.naso72.com
