TECH support!!! NEED A GOOD ANSWER with lots of details on: starter problem
  • TECH support!!! NEED A GOOD ANSWER with lots of details on: starter problem
    When I go to start my tigershark 640 the engine turns but there is a horrible! Horrible! Grinding whining snarling death to your ears sound that is just nasty I read on a forum that you have experienced this before! So I thought I would ask if its the starter or the bendix... I'm so confused I thought the bendix was in the starter... But idk think it is now that I am reading thru the forums... Please help me just give me any kind of advise... Have to get it running by labor day! :(
    Thanks for reading
    Landon
    Re: TECH support!!! NEED A GOOD ANSWER with lots of details on: starter problem
    You will have to inspect the starter gear, the bendix drive and the flywheel. To do this you will have to pull the front flywheel cover off the engine and look at these items. The flywheel might have to be removed for a good inspection.
