1993 Tigershark
  • 1993 Tigershark
    I just got a 1993 Tigershark from a church that says its been sitting for at least 3 years. Are these worth trying to rebuild and get running or should I just part it out? Is there even a market for used Tigershark parts these days ? I am located in Tampa, Fl if anyone wanted to know. I am also in search of parts for a 2000 Yamaha SUV .... maybe do a parts swap ..
    Re: 1993 Tigershark
    If the tigershark only needs a small amount of work then fix it up and ride it.
      Re: 1993 Tigershark
      I dont know too much about rebuilding these things ... I have been searching the net for a service manual so I can read it and decided if I want to try. It engine compartment is a bit dirty and on the front of the engine there looks to be a plug missing and when I look in it I can see a lot of rust.
        Re: 1993 Tigershark
        You will have to start taking the front housing apart to see whats rusted up.
          Re: 1993 Tigershark
          Do you know wher I can download the factory service manual ?
            Re: 1993 Tigershark
            I haven't seen any for Tigershark on any of the web sites yet.
              Re: 1993 Tigershark
              That sucks .. ill keep looking ..... I also need to work on my Yamaha SUV .... hard to find used parts for it tho .... i need most all control cables ... and i think i need to rebuild the engine
                Re: 1993 Tigershark
                Check the Tigershark section of www.pwctoday.com Lots of PDF manuals flying around.
                  Re: 1993 Tigershark
                  I'm sure they are out there, its just tracking it down.
