Re: 99 xpltd sbt motor toast
one tooth off on the CB scribe is fine. Always oil the bearings before re-assembly. Replace the outer crank seals if you can, those don't like re-installation. If you have to re-use them, coat the edges lightly with grease to get a tight fit.
Make sure you scrape ALL the old case sealer off and apply only a thin layer of anaerobic sealer. I have never used permatex gasket sealant to join my cases. I prefer ThreeBond 1211.
