Acceleration is great, starts up very easy...but when I am cruising at WOT it drops about 1,000 rpm for a second, and it happens every few seconds. Any advise would be great. My valves are turned about half way down.
It could be running too lean and is surging, check carb settings, if they are good then clean the carbs and see if that fixes it.
