Need help please, i bought this ski yesterday and it was starting ok when i bought it, i let it sat over night and now it wont start. It turns over but wont fire up the only thing i did was that the throttle body was stock and i spray some WD40 on the butterfly that holds the throttle cable. Also i check a few things and im pretty shure that i dont have spark but i this point am confuse. Could the landyard key cause a this problem?
2006 RXP wont start.
Re: 2006 RXP wont start.
Any error codes? Your not pulling the throttle open while trying to start it are you? (holding the throttle open while cranking kills the spark and puts it into oiling mode).
You say the throttle body was "stock".. do you mean STUCK? If so, it might be stuck open, which in this case same thing.. Ski is in oiling mode.Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
Originally posted by dsolie View PostAny error codes? Your not pulling the throttle open while trying to start it are you? (holding the throttle open while cranking kills the spark and puts it into oiling mode).
Yes, it was stuck. Now is no longer stuck since i unstuck it using WD40 and spining the bolt left and right. But i will make shure that is not open. Thanks
Spinning what bolt? The butterfly and idle set timing is static and set at the factory... You might have messed up your throttle body.Dan Solie -
TB's are not too expensive. I would try and find a used one off of www.pwctoday.com. Probably looking at $200ish?
The main thing is to NOT get a salt water unit. Yours being stuck is common with salt water skis. The bushings swell and lock the butterfly in place.Dan Solie -
The TPS is the sensor that tells the motor where the throttle is. So, if it's stuck, Oil mode...Dan Solie -
