Flooded the sea doo engine with water
  • Flooded the sea doo engine with water
    We forgot to put the drain plug in the sea doo and it filled with water and into the engine intake. We have pulled the plugs and spun the engine forever. The engine will still not crank even though the plugs are firing.
    You should check the electrical box to be sure there was no water taken in there ...
    Which motor or machine are you refering to?
    Thanks for All the Help !<br />Blaine
      i'm sorry but yours plug are not firing yet it is still water in the motor check the videos of SBT tech 21 ingesting water title : :its:
        charge the battery [img]graemlins/crying.gif[/img] it may discharge a bit and check all the connections for water in side
