The last time I had my ski out I had to be towed about 4 miles because my ski was over heating. After getting back to the dock and getting my ski on the trailer I found the problem. The hose that goes from the pump through the hull was just hanging. The hose was still attached to the pump but were it attaches to the fitting on the hull was broken. The plastic male fitting is still in the hose. I looked on line and tried to find this through hull fitting but can't find it on any of the parts drawings. Does anyone know how I should go about fixing this? Is this fitting molded into the hull and is part of the hull? Thanks
2004 STX 1100 Di hull fitting broken need help
Re: 2004 STX 1100 Di hull fitting broken need help
It’s molded into the hull, you would have to find another tube to slide into the existing hole and glue it in then find a way to re-attach the shaft hose. Other people have had the same problem and fixed it this way.SBT Tech Support is here to help with your problems.
